First drive m998 quirks,noises, nature of the beast ?
auctionaddict
15
blue ridge, ga
Hey guys, I finally got her running after a month of work !!
My first time in a hmmwv so I have a few questions.. I searched but still not 100% sure..
1- Is the loud gear noise/whine normal at speed ?
2- Temp 180-190 but climbs to 205-210 then fan engages ?
3- Im in N. GA. Looks like I need my alternator rebuilt, It wasn't charging at first, then started, then quit again.. Where is a good place to send it ??
Here is a partial of work done...
Rebuild pump
Rebuilt injectors
Rebuilt radiator
New fuel pump
New ground upgrade
New water pump
New fan clutch
New glow plugs
New smart start system
New batteries
New belts
New hoses
New filters (all)
Thanks !!!!!!!!
NDT
5,918
Camp Wood/LC, TX
Looks a lot better! They are loud, but no gear whine should be noticeably louder than the 6.2.
panzerwillie
104
miami florida
Looks good , my winds a little while going down the road, it did with TB400 and now with the 4L80E, same T/C so i believe is from there, as long as everything else is good, as far as the temps they seem normal....
ke5eua
40
Baton Rouge (Central), LA
Looks good.
I used to hate that whining sound. Really noticeable in the 1151s, but as far as I can remember, when you top them out she whines about it.
Just remember, you can get them suck, I've seen it. Never myself in a 998 but I've seen guys who thought you couldn't sink a rock call for recovery.
vitamink
Indianapolis, IN
Be sure to check all your geared hubs have gear oil in them. Mine had a whine for a while…until my hub grenaded on me. My 6.5 runs hotter. It gets up to 230 and the fan kicks in.
FloridaAKM
392
Gainesville, Florida
Looks good, now aren't you glad that you stuck with it. Gotta love that N Georgia a/c system you have too, it will be great for a few more months till the cold weather really sets in.
auctionaddict
15
blue ridge, ga
I know of no whine....it's either geared hub GO starvation or a diff going out, or GEar oil starved.
All fluids are clean and full. Nothing gets hot on a short test drive except the transfer case, And its not that hot.. Looks like its been into before..
Its really hard to tell where its coming from !!
Retiredwarhorses
3,893
Brentwood, Calif
Could be a tcase...you are using dexron III in the tcase correct?
i usedd to live on a slight hill, I would coast the truck with the engine off to listen for odd noises to see where the yep were coming from...LOL, I even have run beside the truck with the wife driving to find the source of noises...don't laugh, it works.
