First time 5 ton owner
Ajax MD
1,415
Mayo, MD
Ejection seat.
Just kidding. On my truck, in that location, the cable is to supply or cut off fresh air. You should see a cable running to the passenger's side footwell, to a damper. I have another t-handle that flaps between heat on your feet and defrosting the windshield. Of course, your truck is so heavily modified that I could be totally wrong.
RhinoTAC
Troup, Texas
it's settled...I would like to armor mine now...
Its not cheap, That I can promise you. When they built this truck the entire body was removed and built new using all AR500 plate steel. Its thickness varies from 1/4in up to 1in. The troop pod or TAC will seat up 21 men fully kitted out and 3 in the cab or 1 driver and 1 gunner in the turret. The glass is also bullet resistant with thickness at around 4in all the way around. Its not fast by any means. To even get to 45mph it takes a lot of effort and ton of fuel. Once I get the TAC pod removed I should be able to make her move along faster and consume a lot less fuel. Right now I average about 2.5mpg. I am still new at learning about the M809 series. I was a Grunt in the Corps so mechanics wasn't my specialty. I did however pick up an original paper back TM manual on ebay and I been reading it a lot. My next task is to replace the front axle boots as they are torn. And one day tackle the fuel throttle body as it has a slight drip from the throttle shaft seals.
RhinoTAC
Troup, Texas
What are your plans for it otherwise, if any?
I bought it to promote my business Texas Tactical Training Center. I use it in parades, concerts, open air venues just about anything to advertise the company. Eventually it will be used to shoot belt feds MG's from and it's on loan for any small police agencies that need it who cant afford armor for their officers while serving high risk warrants or barricade situations
