- 10,878
- 798
- 113
- Appomattox, VA
Except for the one time I painted a M416 trailer with a case of rattle cans, this is the first time I will be painting up a truck using a spray gun and a compressor. Will be wire-brushing the truck tomorrow as good as I can, and spraying red oxide primer. Questions:
1. How long do I have to wait for the primer to cure before I paint, for optimum results?
2. I know that when using paint (I have 24087 Gillespie in gallon cans) you have to mix it with a little thinner. What product should I use, and how much?
3. Do I need to thin primer, or just use it straight?
4. What is the optimum spraying pressure for an HVLP (or is that HPLV?) spray gun?
5. I plan on doing one solid coat or primer, and later on, one coat of paint. Is this enough, or do I need to do two coats, like I'm painting my house?
Thanks for feedback, you guys are great!
