Flame heater check valve
fsearls92
154
International Falls, MN
This thread helped out alot, mine started pouring out fuel yesterday. Spent time in between family and thanksgiving and got it fixed. I went to O'rielly's since they were the only place open on thanksgiving and they had the o-ring I needed. Tested it out for a short drive and no more leak. Thanks
randini
salt lake/utah
I finally got around to replacing the O ring last week. I thought I would be smart and try to do it without removing the valve. It was way too much work. I did just take it off, and it was easy after that.
deuceaid
Banned
915
149
Yucaipa CA
The previous owner took off the line on mine and pluged it. Does anyone know what type of fuel line is used, after searching someone said plastic , but what type and where can I get it......
Also, I am guessing the previous guy had this problem, is there any other reason to take off the lines, and how do I test it once I replace everything?
And thanks to all the previous posters (unless Your name is Roger, live in chino, and You took off the lines):razz:
