Flip a switch to use gas?
Micmada
211
Florida
Some guy at Walmart talking to me about my M35 and he be like “yeah I drove those trucks in the Army back in the days blabla….can use any fuel,just had to flip this switch if you ran on gas”.
is there such a switch? Or is it a different engine?
  • Like
Reactions: HDN
Micmada
211
Florida
Nope. His mind is clouded now.
Anything other than AV gas is OK, mixing fuels permissible.
BTW, if any of you are in an attainment area and have to pass a smog test, running it on straight gas will net you a better score on CO2 and particulates.
Conelrad
I know. I often have those “former” new experts coming up to me and telling me how my truck runs. Drives me crazy sometimes.
Micmada
211
Florida
Conelrad
Interesting. I hear alcohol is about 120 octane. I once read in article (that I cannot find anymore) that 117 octane xylene or toluene was used to improve cetane in some additives, but I might have seen a mirage because that stuff is too dry. What you say makes sense about high octane being a negative on cetane, since both are opposite, so to speak. AcGas uses lead for ignition delaying, though.
  • Like
Reactions: HDN
G744
3,684
Hidden Valley, Az
It is simple: Lead or other Octane raisers in gasoline retard the flame front upon ignition to stave off knocking, but that makes it harder to ignite on time in a Diesel engine.
The only thing I worry about running used oil in my trucks is the residual acid level. I have found that testing my used oil usually isn't that acidic so it gets filtered and goes in my fuel tanks. I suspect this is about the only good that comes from low-Sulfur or oxygenated fuels.
If it really turns the blue Litmus paper red (usually from friends that save it for me), I use it to start manure piles on fire.
Conelrad
ldmack3
1,739
N. Central Idaho
Had a guy tell me the biggest concern was that if bumped in gear the engine would start and run backwards.
  • Wow
Reactions: HDN
DaneGer21
1,162
Creston, Ohio
Actually, on some trucks that have dual tanks, a switch could be used to use fuel from a different tank, which could have “different” fuel in it. He isn’t wrong…
  • Like
Reactions: HDN
glcaines
2,465
Hiawassee, Georgia
When I was in the army, I saw a deuce left in gear that was bumped from behind and it took off with several guys chasing it. It must have been in 2nd or 3rd gear because it was moving fairly fast, but one guy caught it before it hit anything. It was a severe penalty to leave a truck in gear - parking brake only.
INFChief
1,344
New York
No switch. Just dump whatever you had for fuel in the tank.
My wreckers had dual tanks and there was a LEFT & RIGHT tank diverter valve to pull from which ever tank you wanted.
Now I’m trying to remember if it had a L & R switch for the fuel gauge?
98G
Former SSG
4,170
They do. Switch in the dash controls where the fuel gauge looks. Lever next to driver seat controls where fuel comes from.
I know of at least two people who thought the dash switch was all that was needed.....
HDN
4,890
Finger Lakes Region, NY
I'll have to remember that. I've always parked stuff with manual transmissions in gear, even my dad's WW2 and Korean-era gassers. But diesel doesn't need an on switch to work unless there's an electric fuel shut-off solenoid valve.
ldmack3
1,739
N. Central Idaho
My A2 has 2 tanks.
There is a switch for the quantity indicator, a switch for pump select and valve in the floor for tank select. I considered making the indicator switch a double pole to combine with pump select but I figured there will be times I want to double check what is in the other tank without turning a pump off and another on. It does draw without the pump on at idle but I've never tried while at cruise.
Micmada
211
Florida
I started the deuce in gear after driving around the m923, forgot it was not automatic. Almost drove through my son in law's and daughter's house. That would have been a doozy, dad.
