Flip a switch to use gas?
dmetalmiki
2,034
London England
Actually, on some trucks that have dual tanks, a switch could be used to use fuel from a different tank, which could have “different” fuel in it. He isn’t wrong…
M62 wreckers have a fuel tank switch....only for transfer though..depends what's transferred...others have dual tanks..'and,'..so.
  • Like
Reactions: HDN
INFChief
1,348
New York
I'll have to remember that. I've always parked stuff with manual transmissions in gear, even my dad's WW2 and Korean-era gassers. But diesel doesn't need an on switch to work unless there's an electric fuel shut-off solenoid valve.
The fuel pumps are electric and shut off when the master power is turned off.
  • Like
Reactions: HDN
INFChief
1,348
New York
Running your deuce on straight gasoline? That falls under the EMERGENCY ONLY category! At least you wont have to worry about MPG because it wont make it that far!
I never saw anyone run a “multi fuel” on straight MOGAS. Because the diesel would turn to gel in Germany we would add alcohol to keep it thinned out. Sometimes we might dump 5 to 10 gallons of MOGAS in the M60A1 (A2 & A3) tanks or other tracked vehicles.
Micmada
211
Florida
Gasoline is a thinner that will eat up seals or harden them too. I do not even put any in winter as some mix it in. In the M923 I put Kerosene with dieselfuel lube like Howes. This being said, when the engine is warm and restarted during a warmer day, the truck will make a puff of white smoke with a distinct slap at start up - similar to when using ether. I never get that with diesel at warm start up. So,I do not like to do it unless I have to when it is -10 outside. The block heater and the heat exchanger coolant pump combo I installed have kept things pretty warm-on cold days, though. The pump itself warms the coolant alone.
williamh
693
SanDiego Ca.
Don’t let these guys fool ya. There’s a small switch under the truck just above the transfer case so you can use gas. It activates the catalytic converters in the turbo. Also there’s a lever to be able to generate the 1.21 gigawatts to power the flux capacitor. 🤣🤣🤣🤣
porkysplace
1,494
mid- michigan
You get much -10 weather in Florida ?
INFChief
1,348
New York
I remember cold war vets talking about 60/40 mix of DF2 and JP4 while cruising the Autobahn. Some crazy thing about flames coming out the stack.
I can run my Deuce on straight gasoline, but then again, it is a gasser lol
No flames. They’re exaggerating BIG time. We’ve run a variety of fuels along the DF & JP lines include JP8.
  • Like
Reactions: HDN
