- 9,576
- 211
- 63
- Dickson,TN
I decided to do some work on my m105a2 trailer today so I could pull it better with my Dodge 2500. First thing I did was flip the lunette. After hearing all the horror stories about them being rusted in place and by the looks of mine I thought it was going to be a long day. The cotter pin was rusted in place and took a while to get free and then I tried to loosen the nut. It wouldn't come without heat and PB blaster. I backed the nut off to the end of the threads ( to protect the end on the threads) and then inserted a wood splitting wedge between the nut and the place where the jack latches in the upper position. I drove the wedge in tight and then hit the end of the ring with a sledge hammer. It poped right out. I wire brushed everything clean and added liberal amounts of anti-sieze and put it all back together.
The only other problem I have is the jack was pivoted to the side and froze solid when I went to pick it up at GL so I had to to chain it up so it wouldn't drag the ground because it won't latch in the upper position unless it is straight. I tried to free it with heat, a come-a-long, and a long bar but it was like it was welded. I finally got it straight so it would latch up after alot of beating, prying, and cussing but it's still not free. I always say I'm going to take pics of projects while I'm doing them so I can post them but I always get caught up in the project and hand and don't remember to take pics untill it's over.
