Dabba
- 0
- 16
- Long Island, New York
anyone use some sort of floor mat or tempory mat? Im chipping up my paint in my floor pretty good and i think im gonna rattlecan it for now, how do you guys deal with this?
You can get the same stuff from your local auto parts store. There are various brands on the market. Advancedauto sells a roll-on or spray versions. $9 a rattle can. $68 for the roll on gallon kit with roller and tray included! Brand is Dupli-Color. They have some nice how to videos on-line.I'm thinking of Rhino lining mine once I get some rust spots and leaks taken care of. I'm not sure how much it would cost though.
We removed everything we could unbolt or unscrew, including the black kick panel you mention. We did not remove the rear seat belts for fear the bolt heads would strip. They are in there to stay!Did you unbolt everything from inside your 09? I noticed that in one pic, the black metal bar in front of the rear seat is not covered. Did you remove it? Did you just do the floor or did you do the roof as well?
The stuff at the stores (Duplicolor, Herculiner, etc) IS NOT the same as Rhino Liner and LineX type stuff. I've had both and currently have Herc on my Tracker. The cheaper stuff you roll on is more like a paint with particles of something in it. The spray on stuff is a thick coating of some sort of poly material. You get what you pay for but depending on your needs and budget you can be served well by either.You can get the same stuff from your local auto parts store. There are various brands on the market. Advancedauto sells a roll-on or spray versions. $9 a rattle can. $68 for the roll on gallon kit with roller and tray included! Brand is Dupli-Color. They have some nice how to videos on-line.
I bought the stuff to coat the metal floor inside the expandable box of my M820A2. I may do the floor in the cab at a later date when i can sandblast it clean. It requires 70 degree temperature for proper adhesion.
BTW Rhino dealer wanted $10+ per sq. ft to do the back of my truck! It was over $1600. Figuring no more that 3 gallons of PAINT that is a lot of PROFIT for them! ($55/gal on Ebay shipped!)
Tomorrow should be 71 here so I will try to apply it and let you know how it works out.
