FLU 419 High Engine Oil Pressure
Suggy
Duluth, MN
Apologies if this is a repeat thread. The oil pressure on my Unimog is running high, 75 psi. The motor has approximately 200 hours, 1100 miles since a military rebuild. Last year the engine oil pressure was running 35-40 psi. Currently it jumps to 75 psi about 10-20 seconds after start up. I’ve replaced the oil (AMSoil 15w40) and filter. I installed a new oil pressure sender and double checked the reading with an engine pressure gauge. Despite my efforts the engine oil pressure remains at 75 psi. Any recommendations would be appreciated. Thanks
glcaines
2,482
Hiawassee, Georgia
The oil pressure on my FLU419 is right at 75 PSI when I start it up cold. Once the engine warms up and at idle, the oil pressure is around 35 - 45 depending on how warm the engine is. Once warmed up and the RPMs are high, the pressure is around 70. I'm running 20W-40W oil. I recently did an oil and filter change and my pressures didn't change. I don't think you have a problem. According to the TM, the oil pressure should be as follows:
Minimum Oil Pressure At Idle: 9 PSI
Normal Oil Pressure: 29 - 73 PSI
To me, 9 PSI at idle sounds like too low a number to me. Also, a normal range of 29 - 73 PSI sounds too wide to me. However, that is what the TM says.
The FLU farm
1,263
The actual midwest, NM.
It's rare that someone complains about the oil pressure being too high, in anything.
But if it used to be low, maybe due to dilution, and is now what it should be, I'd be happy.
Suggy
Duluth, MN
Thank you glcaines and FLU Farm for the prompt responses. I will check to confirm oil is flowing through the head when I get home. If so I will likely begin using it. Many projects to finish prior to winter.
