FLU-419 Hydraulic Tools Not Working
kminer
Redding, CA
Anyone know of a trouble shooting guide for the FLU-419 hydraulic tools? Can't get fluid to the coupling hoses.
Observations:
  • Loader and RPM switch on the back both work properly
  • Both hydraulic fluid tanks are full
  • Pressure is fine
  • Tool Switch is properly wired.
  • Front hydraulic pump appears to be working properly
  • Am not sure whether fluid is getting to the oil cooler either, but the fans do work
Any suggestions, manuals, etc....?
Many thanks,
K.M.
glcaines
2,806
Hiawassee, Georgia
You say that the tool switch is properly wired. Have you checked to make certain that the tool switch is functional? If the tool switch is functional the next thing to check is whether the hydraulic tool solenoid is hooked up properly and is functional. Do you have copies of the electrical schematic and the handout? The wiring and hydraulic circuits are shown in the handout. I've attached copies if you don't have them. The handout is particularly useful for an issue like you are having. I had a copy of the electrical schematic printed out on a 'C' size drawing and had it laminated for easy viewing.
Speedwoble
303
New Holland, PA
I had a time that my tool switch was dirty and did not work. I switched the wires for the loader valve behind the cab with the hydraulic tool valve. Left a wrench wedged against the loader switch and was able to verify tool operation. You could also have “soldier B” hold the switch. Since you know the loader switch works, you know the power and wiring for it are good and the front pump is good. If switching the loader wires to the tool valve doesn’t work, then it is a valve issue.
kminer
Redding, CA
Observations:
  • Pressure is fine
Many thanks,
K.M.
Thanks for the info-- greatly appreciated.
Will let you know how it goes.
peakbagger
350
northern nh
That gremlin popped up on mine. I have not chased it down yet. Remote loader switch works, work lights work but remote high idle and tool solenoid does not. It may be two separate issues but suspicious.
FYI problems with the rear switches are a known issue with a suggested fix. There is service bulletin on this problem. There is collection of these bulletins at this location
#38 has the recommended fix. While you are at it you may want to review the other ones in case your SEE did not get the fixes. My guess is the reconditioned ones (AKA Recapped) should have the fixes. Note, some like this one #38 has multiple issues covered.
The remote tool system is also covered in the electrical diagnostic section of the technical manuals.
glcaines
2,806
Hiawassee, Georgia
Your link is dead.
glcaines
2,806
Hiawassee, Georgia
The 21 gallon tank has a filter P/N HC2124FUN8H, NSN 4330-01-224-5508
The 11 gallon tank has a strainer P/N SS100-8N, NSN 4730-01-097-8684
