Greetings,
The throttle pedal on my recently acquired FLU419 is incredibally squeaky and very sticky. I replaced the springs, removed and straightened the hand throttle linkage and lubricated all relevant linkage joints. The squeaky/stiffness of the pedal remains when all linkage is disconnected so I know the problem lies in the pivot arm and bushing where it comes through the firewall into the cab. I picked up a new throttle -pivot and the two bushings at E I. The TM says you HAVE to tilt the cab.... however I removed the access plate and took a couple measurements and it looks like I might be able to weasel the new pivot and bushing in without tilting the cab ( I dont have overhead room or any help to tilt the cab ). Has anyone ever replaced their throttle-pivot and it there something I'm not seeing ?
PS, The pedal is rusted onto the pivot shaft as though it is fused.... any suggestions, cut off wheel ? hammer strikes ?
Thank You
Thank You
