- 3,412
- 1,485
- 113
- The actual midwest, NM.
GP is letting them age, like good wine.Yes, Wes mentioned that he saw several hundreds on another lot. If and when they come to auction is anyone's guess.
Glad you have found a solution that works for you. Many others have similar abilities to hold air pressure while maintaining full features, just by fixing air leaks. I have found the turning radius in 4wd with lockers engaged is reduced due to binding on packed dirt and grass. Also ensure you are using appropriate regulators spas not to send too much air pressure to the axle pressurization system.Still had 30psi this morning, this thing holds pressure great.
Good use of a simple Class 8 valve! I should copy that idea, but will definitely separate the 4WD and locker functions.I installed a new 4wd selector, it is plumbed up with one valve, so when engaging 4x4 it locks the differentials as well. There may be times I could use 4x4 without locking the diffs but if that time comes and it is annoying I will add in another valve. As you can see I made a new plate, got rid of the air brake valve and the STE/ICE wiring, I will never use it anyways.
