FLU419 electrical issues
terridax
Colorado
Hello,
I have a FLU-419 that I bought a few years back. Every once in a while I would encounter an issue where I would go to start it and nothing would happen. Messing with the clutch pedal and continually hitting the start button would eventually get it to fix itself and it would fire right up. I assumed it was something to do with the clutch safety switch, and figured I'd just delete that if it ever got to the point of it no longer working.
Well, now she's stuck and no matter how much I mess with the clutch, I can't get her to even try to turn over. The problem is, I can hear an audible click when depressing the clutch, so I'm fairly sure that's working correctly. I pulled out both the starter button and the keyed switch and tested them both, and they seem to be functioning correctly. I can't find any fuses or relays that seem to be blown/burned out.
While I was messing with things, I realized that sometimes the gauges lose all power, and I can get them all to come back by pushing down on the main power switch. Currently I am working on trying to pull that out so I can test it... I got the cover off that goes over top of it, which exposed two bolts that seem to be holding the switch in. The obvious next step is to remove those bolts, but I am worried that I may not be able to get everything back together if it all drops down. Anyone know how to go about removing the main power switch?
And more importantly, any ideas on things to test to figure out what's causing this?
Thanks in advance,
David
terridax
Colorado
I have made progress in testing, but have not been able to find the issue.
I have tested the main power switch that comes right off the battery, the main keyed switch in the dash, the starter button, and the clutch switch... they all needed to be cleaned up a bit, but seem to be functioning and pass resistance tests. What else would be in the way of power getting to the starter? Is there a relay or something that I can check?
Is there any way to bypass the ignition system and jump power directly to the starter to see if the starter itself is the issue?
Guyfang
25,837
Burgkunstadt, Germany
You are assuming. Assuming can and will bite you on the butt. Resistance tests are not reliable. Voltage test is the only real way to test.
Do you have this document?
terridax
Colorado
Still struggling to figure out what the issue is. I've read through hundreds of pages on here, gone through all the manuals, stared at the charts for hours... none of it makes any sense to me. Can someone please write out a procedural list of how the starting system is supposed to work? I have no idea if I should even be looking into things like the cold start system, because I cannot figure out if anything in there would actually prevent the start system from working correctly.
The main switch is getting 24v, the clutch switch causes a clicking noise to occur on the passenger side of the motor so I assume it's working correctly, and yet when I hit the start button I get absolutely nothing. Jumping the poles on the starter solenoid gets the starter to spin, but it doesn't engage. Please, someone explain to me how to go about figuring this out as if I'm a complete moron, because I apparently am.
glcaines
2,707
Hiawassee, Georgia
I once had an almost identical problem with my FLU419. Sometimes it would fire right up and other times nothing but a click. I went through the checklist to no avail. I was convinced it was the starter and had it rebuilt, especially after I looked at the starter, which was very rusty and corroded. It was not the starter but the condition of the starter indicated that it needed help anyway and it only cost me $100.00 for the rebuild. It turned out to be one of the five relays under the hood directly in front of the driver. I'm sorry that I don't remember which one was faulty. However, replacing the relay permanently fixed the problem.
Guyfang
25,837
The click you hear is maybe one of these relays. Ad a click is not assurance that it works.
1. KBI Sensor switch.
2. Starter lock out.
3. Starter Repeat Lock out.
terridax
Colorado
Welp, went ahead and replaced all 5 of the 5 pin 24 volt relays in hopes that my previous testing of them was insufficient as you all seem to be suggesting, but I'm back at the very same spot, no difference. What next?
terridax
Colorado
I would recommend following the troubleshooting chart in the TM. It is very good and easy to follow.
I wish it were as easy to follow for me as it seems to be for you... every step takes multiple layers of decryption to figure out what it's asking me to do. I've tried going through the steps many times and have never made it far because of exactly that reason.
I'm stuck on step 8, page 3-72 of TM 5-2420-224-20-1, page 148 of this PDF: https://support.expeditionimports.com/hc/en-us/article_attachments/205692587
It says to check for voltage on wire 12 (10), but I have no clue what the rectangle labeled (10) in the diagram is supposed to be. I've searched around the firewall for hours trying to find anything that resembles the pattern of rectangles in the image, and I see nothing.
terridax
Colorado
The number 10 refers to the diagram. It is showing you where wire 12 is located. The arrow on the diagram is showing you where to find wire 12.
Yes, I am aware that it's referring to wire 12 in the diagram. The problem is that I have no clue what the diagram is a diagram of. It's not labeled, just shows an arrow coming from what seems to be a plug, and nothing anywhere near that plug resembles what's shown in the diagram.
glcaines
2,707
Hiawassee, Georgia
I believe that wire 12 goes to connector A23 on the back of the fuse box 1, but not 100% positive. I had to replace the entire front wiring harness with an NOS wiring harness and found that many of the connections on the back of the fuse boxes had been moved to different places by the Army than the wiring diagram showed due to what I assumed was previous problems. My original harness showed extensive previous repairs, probably due to mouse damage.
