Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
The ignition switch fell down inside the dash- how do I access the area behind and below the speedometer, etc.? The key and retaining nut are still in place. I assume that it (the part w/wiring) has broken off. Thanks, Gary.
Any chance you can get at by removing the defrost outlet?. Getting to behind the dash is major project and PITA due to the front end loader as you need to do from the outside under the hood. There is fresh air and defroster duct work in the way that has be removed.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
