FLU419 SEE HMMH HME Owners group
glcaines
2,830
Hiawassee, Georgia
Check the small rubber hoses at the front wheels first. Easy enough to do, and I've had two go bad.
You saved me some time - thanks. The hose on the passenger side is completely broken in two. I'll replace both sides. They are very easy to get to. I'm sure that is the problem.
The FLU farm
1,497
The actual midwest, NM.
You're welcome.
I happen to know since the HMMH lost 4WD in a rare case when I needed it. Got out and heard air escaping at a front wheel.
Replaced both hoses and have had functional 4WD since...as far as I know. At least there's no pressure loss.
MajorMogger
50
Texas
I'm having a hard time determining where exactly this portal axle leak is coming from and thus how to fix it or what part I need? It's the front driver's side axle.
The other axles don't have any grease on them just the green paint. So I guess this one has been leaking for a while though I don't recall it being noticeable dripping onto the inside of the tire like it is doing right now.
4WD and Synch lock still work fine last I checked.
It's definitely an oil leak. At first I thought my omni-pee dogs had gone under there and peed on it but my first clue was that only one was wet. "Hm...they usually mark every tire....something must be up", I thought to myself.
MajorMogger
50
Texas
Does anyone know where or how to get the bit/tool holding thing that goes into the side toolbox? I think it's some kind of molded plastic or something. But I can't really carry my tools properly without it it seems because they rattle around.
Also, the clamps that hold up the jackhammer and drill - are they supposed to be metal on metal with the tool or is some kind of rubber missing?
20,815
Possibly the box like this?
From the TM, TM 5-2420-224-24P-2 posted here on the site. PDF Page684, 0360 00 is the page number in the document.
Chances are after re-reading what you asked, this might not be it - but if we can figure out what the box might be called - maybe it will be in this book?
EDIT: Found some really detailed instructions on repairing four of the hydraulic tools.
Section I.
Section Il.
Section Ill.
Section IV.
Page
Hammer Drill Repair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21-1
Impact Wrench Repair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21-15
Pavement Breaker Repair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21-24
Chain Saw Repair . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21-37
TM 5-2420-224-34, Page 21-1
glcaines
2,830
Hiawassee, Georgia
If you look in TM 5-2420-224-24P-2 on Pages 106 and 107 you will see the tool tray, Item 26.
Name: Tray, Pneumatic Tool
P/N: 419-585-70-44
NSN: No NSN Assigned
CAGE: 64678 Daimler Trucks North America
You will likely need to find a FLU419 that is being cannibalized to find that tray.
Also, the clamps that hold up the jackhammer and drill are metal on metal with no padding. It is surprising to me that they didn't design the clamps with some rubber strips for padding.
MajorMogger
50
Texas
Thanks for this info. I will probably do some kind of heat formed ABS sheet or something. Maybe I can just lay the tools out on the bench, put a sheet of ABS over it and heat it with a heat gun until it relaxes over the group of tools. I really want to keep them with the unit but the thought of them bouncing around in there makes me very sad.
glcaines
2,830
Hiawassee, Georgia
If you know of someone near you with a FLU419, you could do a plaster cast of their tool tray and then possibly form your own tool tray out of ABS or whatever makes sense. You would then have an almost perfect copy of the tool tray.
MajorMogger
50
Texas
Or, could someone send me a top-down photo of it so I Can see the layout better? I could almost see me putting together a wooden tray with either cleats or routed out sections to hold things together.
glcaines
2,830
Hiawassee, Georgia
I changed the hoses on both sides, although only one was broken. I found the proper 5 mm ID hose at Autohaus AZ - one meter for $9.95. Took me about 15 minutes per side to replace. My 4X4 now works perfectly.
The FLU farm
1,497
I removed all the tools and bits, and the tray, since there are other things that are more useful to me that are kept in the toolboxes.
Anyway, if I wanted the bits and things still in there, and nicely separated, I'd cut out foam for the job.
glcaines
2,830
Hiawassee, Georgia
One thing I did with the tool cabinet is drill a 3/16 inch hole in the lower rear inside corner to allow water to drain out. It is almost impossible to keep rain water from leaking in that tool cabinet if the FLU419 is out in the rain, even if the gasket is in good condition. The tool tray is a two-edged sword. On one hand it keeps the tools organized and elevated off the bottom of the tool cabinet, where water accumulates if a drain hole is not drilled. On the other hand, the depressions for the tools collect water if a substantial amount of rain water leaks in. I was lucky in that my FLU419 came with a brand new set of tools which were painted and had no rust, so rain water has a minimal impact.
MajorMogger
50
Texas
that is a good idea.
