- 3,420
- 1,497
- 113
- The actual midwest, NM.
Well, there's always the more or less direct connection between rodents and the SEE.
In German the SEE is a "gerate".
I see rat and ate in that one wordWell, there's always the more or less direct connection between rodents and the SEE.
I don't have a crystal ball, but I believe these SEEs were in much better shape when they arrived in Texarkana, where they set in a field until mother earth nearly reclaimed them. I made a few pick ups at the facility and some of those SEEs look like they were pulled out of Jack and the Beanstalks back forty . It's a shame, because they probably would have fetched a better price in the pre rat & vine days.I never did get any paperwork with mine, which might be what has saved me from all the electrical work you guys have to deal with.
Mine is not ratified.
I put it on the list for tomorrow to listen for it. If the turn signals work (not sure that I ever tried them) and it's a normal flasher, I should be able to hear where it is.WHERE is the turn signal flasher unit and the turn signal control box or what ever it is called, dealing with getting power to the turn signal switch now.
True, one never knows when a simple navigational mistake could make us end up in Siberia with the SEE. Then being safe at down to -62 degrees could be a good thing.I'd like to keep my antifreeze at the upper limits because it's more capable in my opinion, operating in a broader range of temperatures. Probably never benefit me, but when you need it and don't have it, you're singin' a different tune.
Then, too, a comet could hit us and throw us into a nuclear winter:True, one never knows when a simple navigational mistake could make us end up in Siberia with the SEE. Then being safe at down to -62 degrees could be a good thing.
Since I've lost my passport I couldn't go there anyway, so a mere 30 to 40 percent works fine for me with temps rarely going below minus 20 here.
Good point, Ahab. But I do have several gallons of anti freeze I could add should that happen.Then, too, a comet could hit us and throw us into a nuclear winter:
- You got to be ready.![]()
I'm hobbled up with a foot injury, but after reading the perseverance of my SEE comrades, I decided to finish up the paint job. SEE cab is now painted. I now have the best looking SEE in Fort Towson, oh wait, I have the only SEEs in Ft Towson.Page 3-166 of the -20 is a schematic of the hazard warning lights system, now this makes all 4 corners and the dash lights flash, now looking at this IMPORTANT find, I saw that the brake lights go though relay H and then then what is called the "HAZARD WARNING SWITCH" now the thought is since the the hazard warning lights aka turn signals are flashing due to the HWS, the the HWS MUST be the turn signal flash control, da. NOW look on page 3-111 of the -20 at the schematic for trouble shooting the right turn signal not working, please tell me WHERE the HWS is, because I am so old that me eyes must have missed it on the VERY busy schematic.
The above just reinforces my very INTENSE feelings about this truck, it is a MAJOR POS and a insult to trucks being called a "truck", I have more names for it but the KGR will not allow it. Now going out to find and lay eyes on the HWS, then from there ???, the quest continues.
Ahab, those are factory work lights, which I replaced with dirt cheap LED 60-degree work lights, front and rear.That SEE is a beauty, General Hood; nice! Did you add the spotlight?
![DSCN1242[1].jpg DSCN1242[1].jpg](https://www.steelsoldiers.com/data/attachments/437/437931-d1d778177e74e56f40d43a98020b146d.jpg)
![DSCN1243[1].jpg DSCN1243[1].jpg](https://www.steelsoldiers.com/data/attachments/437/437932-0641074240b839c782ade172cdedbdb5.jpg)
Very nice. The switch from headlight to work light is under the hood on both my SEEs. I plan to reconfigure wiring and relocate switch to inside the cab. Page 46 on my to do listAhab, those are factory work lights, which I replaced with dirt cheap LED 60-degree work lights, front and rear.
Unlike Mr. Hood, I thought it was better to see good than to look good. And the installation was pain(t)less.View attachment 641647View attachment 641648
On the SEE the protective...um, hood, was left off, which helped quite a bit with visibility in general.
How many chapters are you up to now; and is that single-spaced or double-spaced?Very nice. The switch from headlight to work light is under the hood on both my SEEs. I plan to reconfigure wiring and relocate switch to inside the cab. Page 46 on my to do list
Just scribbled reminders, unlike the bold print lists my wife gives meHow many chapters are you up to now; and is that single-spaced or double-spaced?
Funny you should mention that. Early on I also thought about moving the switch, and yesterday, when looking at the headlights, I realized that there's no reason to ever use them.Very nice. The switch from headlight to work light is under the hood on both my SEEs. I plan to reconfigure wiring and relocate switch to inside the cab. Page 46 on my to do list
