FLU419 SEE HMMH HME Owners group
Another Ahab
4,842
Alexandria, VA
I was really lucky in that the place that sold me the FLU419 several years ago told me it didn't come with any of the hydraulic tools. I purchased it sight unseen, only photos. When it arrived I was very pleased when I cut off the padlock and found all three hydraulic tools and all bits. The rock drill was brand new and still painted orange. The FLU419 had just come back from Afghanistan. Papers under the seat showed that it had also been to Kuwait and Iraq.
"Christmas in July", glcaines!
Zweet!!
Another Ahab
4,842
Alexandria, VA
Looking to sell my FLU. Sad days, but I need the freedom more than the tool. Anybody have suggestions? It's been a solid machine but I need to find the right buyer.
Sorry to hear the sadness, pinsandpitons; but I guess changes-and-churning happens to everybody one way or another.
You know she'll find a good home from someone, likely even somebody on this site!
The FLU farm
1,485
The actual midwest, NM.
I know the feeling. I've started looking for a good home for the HME.
It'd be hard to replace that one if/when I come to my senses.
glcaines
2,772
Hiawassee, Georgia
I think about selling mine every once in a while. Then I end up using it and am thankful I came to my senses. I have used mine on several large projects at home, including the hydraulic tools. I just used the chainsaw today cutting up a large poplar tree that came down blocking my road and hauled off the large logs with the FLU. I've actually had two people try to buy mine from me, but none in the last year.
glcaines
2,772
Hiawassee, Georgia
I'm having trouble with my FLU419. I replaced the front wiring harness with an NOS harness. What a pain that was. Everything works fine now, or at least I thought it did. Everything works on the backhoe and the hydraulic tools. 4X4 and differential lock work fine. Since replacing the wiring harness months ago, I hadn't driven it on the highway at speed. I discovered that the intermediate speed control doesn't work now. It worked fine prior to replacing the wiring harness. It stays in low range regardless of where the collar on the shifter is located. Top speed is now ~25 MPH. The only electrical connections I see on the schematic is wiring to the panel light showing that low range is selected. Even though it is permanently in low range this light doesn't light. The bulb is new. I know the switch for the circuit is on top of the transmission and is closed or open as the piston moves back and forth between high and low range. I suspect that the piston isn't fully in the low range positon which would close the electrical switch and illuminate the light. I'm suspicious that the problem lies in the pneumatics, but it is also troubling that the problem developed when I replaced the wiring harness. I should also confirm that the pneumatic pressure is ~106 PSI. A while back, I rebuilt the top of the transmission with the pneumatic piston for the intermediate speed control. When I re-assembled the unit, the piston moved freely and had a new O-ring and was lubricated. It worked flawlessly after the rebuild, so I don't think that could be the problem. Does anyone have any ideas?
Another Ahab
4,842
Alexandria, VA
I'm having trouble with my FLU419. I replaced the front wiring harness with an NOS harness. What a pain that was. I suspect that the piston isn't fully in the low range positon which would close the electrical switch and illuminate the light. I'm suspicious that the problem lies in the pneumatics, but it is also troubling that the problem developed when I replaced the wiring harness. Does anyone have any ideas?
Man. That is such a P I A (pain in the afterdeck), when you:
- go and do everything right to make a fix
- and then you get a problem you didn't need from all of that effort
Hang tough like Pinsandpitons (must be a climber!), encouragingly suggested.
And keep in mind we want you to succeed!
brandan34
46
Southern Oregon
Is this one of the things where the switch on the clutch peddle needs to work before it sends air to the cylinder? If I remember right there is an electric selenoid that needs power to allow the air to move things. If so maybe check that it is getting power.
majkowskid
46
The Great State of Texas
Gary,
I had a similar issue when I did my wiring harness! And you actually helped me when I was getting my shift actuator to work. My problem was actually wire damage going to the actuator itself. It runs on ground to the air solenoid setup on the side of the transmission. I’d be tracing ground that connects to the switch on the air shift solenoid.
Another Ahab
4,842
Alexandria, VA
1989 flu419 military excavator
Family owned for 10 years, 8 of which were in storage.
Less than 200. (Yes 200) original miles
Engine hours are less than 300.
Purchased from family member 2 years ago to do some ranch work. Now complete and loooking for smaller machine! Will consider trades for mini excavator, diesel only, with cab/ac.
The flu419 is a military excavator which has a front end loader and foldable case m35c excavator on the rear, as well as remote hydraulics on hose reel for operating hydraulic equipment like chainsaws, jacks, pumps etc.
Powered by a Mercedes Benz om352 diesel engine, it’s an absolute beast. Portal axles for lots of ground clearance, 16 forward and reverse gears, with air splitter, high and low range. 4 wd with air locking differentials. This thing goes absolutely anywhere.
I replaced the entire wiring harness behind dash (damn mouse) and absolutely every light, horn, heater, everything works like new.
4 hydraulic cylinders professionally rebuilt this month as they had microscopic leaks.
2x12 volt batteries replaced last year.
New filters all around, and all fluids replaced.
New diesel primer pump although you’ll never need to prime it. Thins thing starts like a brand new truck. Will drive approximately 50 mph (I’ve had it about 45 with room to go)
You will need a large flat bed trailer to get it home. Weighs approximately 15000 lbs.
Also have military m1102 trailer that is like new I can sell also for 2000$. All aluminum high bed trailer made to tow behind humvees in the desert! Has like new 37” tires. Pintel hitch connection and the flu419 has a pintle connection as well.
Serious buyers only. Located in Robert Lee tx and can show by appointment only.
Cash sales only.
Call or text 325-305-6064
Located in Robert Lee tx, just outside of San angeloView attachment 950078
Flu419 is $32000.
Guessing that beautiful beast will have a new home in a hurry.
Shed looks mighty clean. Got to figure that machine has been treated right.
