Fluid capacity and Filter numbers?
Jarretfd246
Texas
Is there a post that I'm not seeing on here that shows all the fluid capacities for m998 hmmwv?
I just picked mine up on Tuesday and I want to flush the fluids with new ones.
I have a 1989 m998 with the 6.2l .
Oil quantity?
Filter number ?
Transmission fluid type and quantity?
Transmission filter number?
Transfer case fluid and quantity?
Brake fluid capacity and type?
Power steering capicity and type?
Coolant capacity and type?
I tried downloading a manual but it just freezes and doesn't load.
Also are the filters something I can get from orileys ?
Thanks for the help.
porkysplace
1,495
mid- michigan
This thread came up searching using your thread title . Capacities are in the lube order, but if you can't download them you probably need to got to e-pay and buy the TM's on a disc for about $5.
Filters, air, oil and fuel
edit ; price went up they are now $12.99 shipped for a CD with all the TM's on it on e-bay.
suzukovich
142
Gibsonton Fl
Oil quantity?
Filter number ?
Here it is//cloud.tapatalk.com/s/5adb32565379c/LO_9-2320-280-12.pdf
Sent from my SM-J727U using Tapatalk
suzukovich
142
Gibsonton Fl
Also go here
LEO/FD HMMWV Check List & Part Numbers.
Power steering 1 1/2 at a Dex 2 or Dex 3. Do not use synthetic as it will kill your seals.
Oil 15-40 for diesels 8 qts with filter don't use synthetic
Trans Dex 2 or Dex 6 once again don't use synthetic
Air filter, don't need to change. Clean it using air hose.
Brake fluid DOT 5 only.
Oil filter. Use Wix not sure the number.
Hub and Differentials 90 weight gear oil.
Transfer case. Dex 2 or 3.
This is off the top of my head. Use the lube order. You can also GO to the KASCAR web site.
papakb
1,196
San Jose, Ca
Once again for all of you new HMMWV owners out there, the military maintenance manuals are written for peoples of all skill levels and include answers to 90% of the questions we see posted here. They're all available for free to download at multiple sites on the internet. If you own one of these trucks you really should avail yourself of a full set of manuals. The local Chevy dealer isn't going to have your answers and most mechanics that have never served in the military will only give you blank stares if you ask them questions. The more you know about your truck the better off your going to be when there are problems with it whether it's out front of the Piggly Wiggly or 50 miles into the boonies. :tank:
BTW TM9-2320-280-10 is the drivers handbook for the HMMWV and has all the weight, dimension, configuration, and capacities listed in it.
suzukovich
142
Gibsonton Fl
Still need the lube order. Also the dash 2 or 20 level helps with troubleshooting. The 3, 4 & P diagrams and part numbers.. the 10 level is General information and PMCS at the operator level.
Kratos1
South Carolina
Also go here
May I ask why you would not use synthetic? I see the seals on the power steering but what about the rest of the fluids
Hummer Guy
822
United States Louisiana
Also go here
How much of the transmission oil you use?
Mogman
10,434
Papalote, TX
Also go here
DEX 6 is a full synthetic
Terra1936
128
El Cajon/California
Also go here
Great information!
