flywheel housing bolt missing?
treysoucie
houston TX
well i took the deuce to surfside this weekend and when i woke up this morning back in houston i went looking for leaks or anything of the sort. well i found a hole where a screw or cap used to be. anyone know what the purpose is? also im getting a slight drip a little further down the tranny housing now.
91W350
57
Salina, Kansas
You move the plug in the lower part of your photo to that open hole when fording deep water. Otherwise it should be open to allow transmission lube to drain, or engine oil should one or the other leak into the housing. Glen
hoop
14
va
And there is a 1/4" plug on the side of the bellhousing for the vent. And it comes in handy, if for some reason you blow an air line going to your air gauge.:roll:
73m819
320
gainesville, ga.
I am not sure but I think the -10 may also have something to say about this hole
WillWagner
2,725
Monrovia, Ca.
Yes, the -10 has the info and it has been discussed plenty of times. Yet another case of RTM....Oh wait, nobody can 'CAUSE WE DON'T HAVE THEM HERE!!!!
And everyone wonders why these questions keep getting asked over and over :roll:
hdmax
new Lexington, Ohio
If these questions weren't asked over, and over how would some of you get your post count into the thousands? You would have to sit on the side line instead of having something to bit(h about.
I think everyone knows that the search part of this site needs work, maybe the OP searched, maybe they didn't. But there are at least a 2 to 1 ratio of wasted post telling others to search, or it has been asked before than the repeat questions.
Maybe it's because we all need to feel as if we are better then others from time to time.
73m819
320
gainesville, ga.
I disagree, threads like this ARE wasted space when just reading the TMs ( which ALL MV owners should have) would answer the question, NO need for "search", no need for "READ the TM", ect..
I would rather answer the question "I have a problem, I have the TMs but can't find it, where should I look" this is a MVer that wants to find and fix the problem, just needs a little guidance, we all have been there.
the OP is NOT new, his join date is MAY 2010, before the old TMs section went down..
With the TM section down, i don't mind answering where can I find the TMs though search will give the same answer, In fact there should be a sticky on top of the forum in the notices showing where to get the TMS
