- 124
- 10
- 18
- Macon,MO
My M1084A0 fuel / water separator housing was leaking at the pump diaphragm and I replaced the housing. I noticed the water separator fuel bowl had a lot of debris. Closer inspection indicated the fuel bowl heater was broken and small particles were flaking off. TM 9-2320-366-24P-1, Figure 34 shows the fuel / water separator housing fuel bowl (item #7) as part number RK22141. My local NAPA dealer shows the RK22141 in their system. However, their photo does not show the fuel bowl heater or electrical connections.
The Racor website has a brochure that seems to show the heated fuel bowl. However, the brochure part numbers do not match RK22141.
The fuel bowl heater element has part numbers imprinted on the side:
22002 04F
49 93
Internet searches for these numbers comes up blank.
I'm sure someone has already solved this problem!
Does anyone have a source for a replacement heater element only or is the entire fuel bowl required? This unit has splice crimps and heat shrink tubing covering on the electrical leads. I suspect the heater element has been replaced before.
stay safe and stay in touch,
firefinder
![IMG_2290.jpg IMG_2290.jpg](https://www.steelsoldiers.com/data/attachments/461/461831-a32c6f12d1187cda7852a82538db2b11.jpg)
![IMG_2287.jpg IMG_2287.jpg](https://www.steelsoldiers.com/data/attachments/461/461829-096f7b034cda5422d261d943afc1e920.jpg)
View attachment Racor_Fuel_Filtration_-_Diesel-Fuel-Heaters_-_7749.pdf
22002 04F
49 93
firefinder
![IMG_2292.jpg IMG_2292.jpg](https://www.steelsoldiers.com/data/attachments/461/461834-a9f14b63b069d2f4109e16e90d7ded3c.jpg)
