Fmtv crane maintenance manual, hydraulics specs?
tobyS
840
IN
It helps a great deal and it looks like other than the hydraulic power there's a Cannon plug with 12 volt power going to it.
I talked to a shop today and they recommended I set it up with the pto setup. He said he can convert it to a direct flange Mount or stick with the driveshaft depending on how much room is in there. The pump is going to be about 500 bucks I'm still going to look to see if I can find a military pump with the drive shaft
Don't overlook an important point...this system requires a variable displacement piston (or some vanes) pump, pressure compensated, and is not a positive displacement (gear) type pump. Unless that OEM pump comes from an FMTV or HEMTT, it ain't gonna work. I'll grab the pad and go take a photo of mine for the next post.
tobyS
840
IN
Here is what I'm using. Caution when you get the pump that it's direction is correct. Oh yea...and mine is a lot less flow for smaller stuff...like my 2" cylinders that I have 25 of.
8madjack
78
Gold country Ca.
According to the maintenance manual it's a single stage pump I think that's just an ordinary positive displacement pump and I got the impression from the hydraulic guy when I told him that that it was that simple.
tobyS
840
IN
I don't think you understand what I'm saying about the pump.
Yes the driveshaft has to be used because there is not room to flange mount a pump, but if you purchase a pump from a 5 ton 939 series, they are gear pumps...they won't work.
Tell your hydraulics man you need a pressure compensated piston or vane pump that does connect by driveshaft. The one in my picture is a small one. It has the same mount as a gear pump SAE A, B or C (picture is A). That particular pump will be flange mounted on my M35A3, splined input.
I would use the next size up for your application, mine in the photo for my A3 is about 8 gal/min..
My point is it must be pressure compensated variable flow, not fixed flow.
I'm not trying to sell a pump, but I do have one the size you need... a Rexroth, with a straight keyed shaft. I can get more info off it if you would like.
tobyS
840
IN
Not having read the wrecker TM, my observations have been that they use gear pumps, off the tranny and the transfer case. They are positive displacement and not compatible with the valving of the crane that was made for LMTV and HEMTT, with pressure maintaining(compensating)(but 0-full) flow, set at 2500 or so (made for 3000 min). EDIT---man does that sound like garbled up pile of ...
I'm not really sure what you mean by "stages".
8madjack
78
Gold country Ca.
The wrecker I was referring to is the lmtv Wrecker. So can a single stage pump be either positive displacement gear or variable flow vein or piston Style?
I did a lot of reading online and I was under the impression that a single stage was positive flow. I definitely don't want to get the wrong pump. We can talk via p.m. about your hydraulic pump. I was hoping to find the parts together almost like kit form, perhaps I'm being greedy :-D
I think I bought my PTO from you if I remember correctly. As long as I get to set up I need to run to dump hoist and this crane I'm happy.
snowtrac nome
142
western alaska
all those pumps are positive displacement the other option you might see is a centrifugal pump but those are for light liquids like fuel and water. I think what you are asking is do you need a fixed flow pump or variable swashplate pump which would give you a variable floe and pressure. My short answer for a crane or winch is a fixed flow pd pump is all you really need.
tobyS
840
IN
Sure, you got the PTO from me and that is partly why I don't want to see you get the wrong pump. But I'm pretty much the same with all people here, will help when I can. My purchase of the winch unit and determination to make it work has a lot to do with working these issues out too.
Your use of the crane is crossing two different animals re the hydraulics. If you buy the pump from the FMTV it should be one that will work and have the capacity in flow. I thought you meant you would buy driveshaft and pump from an M939 series. Driveshaft....maybe... but you do not need a gear pump.
Here is how the piston pump works.
https://www.youtube.com/watch?v=2mh902AP7Yw
Check out this for the gear pump
/www.youtube.com/watch?v=c6gwU7IHtlo
tobyS
840
IN
Fixed flow and variable flow are two entirely different animals. Fixed flow will not work because the valve pressure port is blocked when the valve spool is in the center position. No flow is allowed to pass. If you have a fixed flow (gear) pump, it simply stalls the engine or breaks.
If the valve had an open center then fluid could circulate and a gear pump would work...like the valve of a 939 series wrecker...that's open to tank in neutral.... and doesn't stop the flow. It's called "open center valve" on the 5 ton wrecker but NOT the LMTV.
Look at the valves and manifold...they look entirely different.
8madjack
78
Gold country Ca.
It's on my "things to do" list, been busy with other stuff unfortunately.
I plan on studying the heck out of the TMs, or hopefully run into a guy who worked on these specifically before actually doing it.😁
Lukes_deuce
127
Long Island, NY
Did some digging for the pump and came up with the following info.
Technical Data | NSN 4320-01-363-2294
CharacteristicSpecifications
MAXIMUM DISCHARGE FLOW RATE22.5 GALLONS PER MINUTE
DISCHARGE PRESSURE2938.0 POUNDS PER SQUARE INCH GAGE
OPERATING SPEED AT RATED CAPACITY2400.0 REVOLUTIONS PER MINUTE
MEDIA FOR WHICH DESIGNEDHYDROCARBON FUELS AND OILS
PUMPING ELEMENT OPERATING POSITIONHORIZONTAL
PUMP ROTATION DIRECTIONCLOCKWISE
ROTARY PUMP DESIGNGEAR
OPERATION METHODPOWERED
INTAKE CONNECTION QUANTITY1
INTAKE CONNECTION TYPETHREADED INTERNAL
INTAKE CONNECTION THREAD SIZE AND SERIES/TYPE DESIGNATOR1.625-12 PTF-SAE SHORT
DISCHARGE CONNECTION QUANTITY1
DISCHARGE CONNECTION TYPETHREADED INTERNAL
DISCHARGE CONNECTION THREAD SIZE AND SERIES/TYPE DESIGNATOR1.063-12 PTF-SAE SHORT
DRIVE CONNECTION TYPECLOSE COUPLED
DRIVE SHAFT TYPESPLINED, INVOLUTE EXTERNAL
DRIVE SHAFT LENGTH32.0 MILLIMETERS NOMINAL
MOUNTING TYPEFLANGE
Lukes_deuce
127
Long Island, NY
To me, since its a gear pump, that means its a constant flow, open centered system. I am not an expert in hydraulics. I have basic understandings due to my use of the systems on trucks and equipment but I could not differentiate between the system types without some more knowledge. Hopefully someone can chime in who knows more.
8madjack
78
Gold country Ca.
That information makes sense based on what I read in the manual a while back , I'm going to have to go out of my way to get eyes on an actual truck, there is an Army Depot base here maybe I can go talk to those guys
Thanks for that research and sharing it here
319cssb
221
Easley SC
Does anyone know the AN fitting size for the m1084 grove MHC ? The hoses are 3/8”, but what size are the fittings?
coachgeo
3,546
North of Cincy OH
is there only ONE model of pump installed on the Allison for the whole range of the MTV's and LMTV's? If so would that make it wayyyyyy over pumped for say winch trucks..... and about right for the trucks with cranes etc??
