- 629
- 24
- 18
- Port orchard, WA
Well the taller gears will put the transmission range into where it was designed to operate mph wise (off the shelf product meant for highway trucks), therefore making the lower gears more useable on hill, so in fact hill pulling speeds may increase. Just like when you put bigger tires on the jeep with out a gear change you lose tons of power. do the gear change the performance is back with loss now due to higher wind resistance, tread friction and rotating mass. I am changing gear ratios for the following reasons. First I have a lot of highway travel to get to where I need to use the truck, no doing it for speed, but to get off the redline at 55, high rpm's equal shorter engine life. Second the transmission gear changes are more usable, now closer to the ranges they were designed for. Third the mpg will increase as rpm's are lower and more in the power band of the 3116.
I also will be adjusting the fuel screw, while watching egt's and may change out the turbo to keep temps down as the 3116 builds heat fast. Not looking for a hot rod, but not afraid to look for more performance. If I blow it up, then in goes a C 8.3
