FMTV LMTV Tire balancing?
Karl kostman
893
Fargo ND
Hey guys I cannot say anything about the how and what type of balancing material works with CTIS but I will say that on my M920 with 1600 tires on HEMMIT rims it did the trick very well. I put 48 ounces of EQUAL tire balancing beads into each tire through the valve stem and the truck was very good going down the road, I even got to experience 16th gear! Prior to this treatment the top speed was about 30 miles per hour, anything over that and it felt like you were bouncing the front end of the truck off the road!
Karl
sargentwolf
st louis/mo
Per the company i called (counteract) their beads are too big to get stuck. He said they have installed them before in trucks with CTIS and it works great, if installed correctly. Dont just chuck the bag into the tire and rebuild, but pour the beads into the tire THEN rebuild.
DiverDarrell
24
Port orchard, WA
Here is an update on my experiment. So far the front 2 tires are done. At times there can be a little vibration either speeding up or hitting a bump gets things smooth again. So far so good, no ctis issues. Much better than before without the beads.
CRayGill
Cherryville, Oregon
So now that it's almost 2.5 years since the last post on this thread, any fresh update? Please!
I'm about to pull the trigger on this myself, so too much information is almost enough. ;)
DiverDarrell
24
Port orchard, WA
Still driving with them, only have around 1500 mile on them though. no issues, seems to work great
Pointman0853
13
Gardnerville, NV
As an update, Mr. Filner has a video episode on YouTube where he used 40oz of antifreeze in each wheel to achieve positive results.
He's pretty resourceful and this may be something to consider.
Pointman
CRayGill
Cherryville, Oregon
My only concern with that would be blowing the AF out when the CTIS deflates the tires...
I'm new to this stuff, so I may be way off base here! ��
Another member and I may be tag teaming our trucks soon, so if we do, I'll report what happens for us.
I' (think) that I'll be using 24oz of beads in each tire on mine. I'm not sure what he's got planned.
We can report back once we're done ����
simp5782
Feo, Fuerte y Formal
9,405
Mason, TN
You do not need beads or antifreeze anything for that matter. If you have a shake then you have a bent wheel, tire separation, or a flat spotted tire. Basically beads on tires of this size arent worth it. I have logged more miles on 14.00s, 395s, and 1600 tires than any member here. I have only ever had to balance one wheel and it took about 8 oz. Of weight from a wheel being bent at one time and they didnt repair it right at Ft Lewis McChord
If you feel a slight shake you can add a counter weight opposite where the ctis valve bolts to the wheel that equals its weight or slightly under just as the 939A2 trucks did
simp5782
9,405
Mason, TN
You can use standard automotive wheel weights. The rim lip is no different. You would need 2oz to 5oz weights
