FMTV MHC supply line connection.
Ray W Cunningham
Dover TN
Trying to find the location of the hydraulic supply line connection. Have a 5K crane that I am trying to power with a power pack that I built to provide hydraulic power to the crane. From the subframe connection where the return line, supply line and hand pump are located at. I have found the hand pump line and return line. Have not been able to locate the connection point on the manifold for the supply line. If someone could send me a picture of where it connects, I would greatly appreciate the help. I have gone through the TM but unable determine the exact location of the supply line connection.
aw113sgte
1,336
La Crosse, WI
Should be able to trace the line easily if you lower your spare. I would be concerned about reservoir volume. The AOP reservoir is not that large.
