FMTV rims on 809-series
steelsoldiers
4,128
Charleston, WV
Anyone using 5-ton FMTV 2-piece rims on their 809-series truck with 14R20 XL's or other tires? If so, how's the offset? Thanks.
Chris
steelsoldiers
4,128
Charleston, WV
They are 395/85R20, but I was planning on pulling those and mounting 14R20's. I'll see if I can get a pic of one of them.
steelsoldiers
4,128
Charleston, WV
The problem is, the are always run the same way on a FMTV. I don't know if you could flip them to run on the back of a 809.
M1075
Oklahoma City
Okay, this is making a little sense now. I bought a lot of 395s from GL and 3 of the tires had 2 piece rims (20 bolts). The rims did have some external CTIS components that I removed. They must have been FMTV, but all along I thought the were M939 series. I used the rims on the front of a M52A2 with 14R20 tires. The offset is fine. It is just luck that I haven't tried to flip them to use on the rears. I don't know if they will work, but I assume they will.
When ordering replacement valve stems for other rims I have, I found out there are two type of valve stems, with one designed to air the tire up from either side and one can only be aired up from the nut side of the wheel. The second one might be from the FMTV rims. I am going to look into this some more. Good thought provoking thread SS!
steelsoldiers
4,128
Charleston, WV
I do what I can :)
That's interesting that you have already tried them out and didn't realize it. Are the wheels lug-centered or hub-centered like standard 939 rims? You would have to convert them to 2-way valve stems or run a flex extension on the rears to keep them aired up. The last stopping point is are the lug holes counter-sunk on the back side like they are on the front?
David, some close-ups would be great.
steelsoldiers
4,128
Charleston, WV
RE: Pictures of FMTV Tires
Great shots David! Thanks. The close-up on the lug holes makes it look like they are beveled on the outside only. I wonder what would happen if they were flipped and run on the rear. If they are hub-centered, they should ride just fine, but if they are lug-centered then I wouldn't think they work.
ARMYMAN30YearsPlus
Parkville, MD
The thing about the FMTV is they are not built as tough as a 900 series or even a duece. I noticed spring issues on one end and saw many of them at their limit with armor on them in Iraq. The lug nuts are hub centered you can see the slight bevel on the spare.
steelsoldiers
4,128
Charleston, WV
Re: RE: Pictures of FMTV Tires
Westech said:
flip your hubs. thats what I'm going to do
That thought crossed my mind tonight. Would that give you the same track width all the way back? I do like the look of the FMTV wheels all facing the same way. The supply of 939 2-piece rims is limited. There should be a lot more of the FMTV rims in the future with the reorganization of the military truck fleets. Hmmm, might have to give it a try. Is anyone on SS running 5-ton hubs flipped?
1,827
RE: Re: RE: Pictures of FMTV Tires
There is one person Chris, on an M813 but I can't remember who.
DMgunn
SE North Dakota
Nice avatar, Westech.
Wonder how many guys here recognize the source. I've got it on DVD, and recommend it to all the M211/M135 owners.
Back on topic - I would be interested in seeing a pic of a truck with those wheels, also. They would look real nice on mine....
1,164
Buggyman...or the guy who just sold the 813 out West to buy the HEMTT?
