HoustonDeuce
- 1
- 6
- Houston TX
I have a set of FMTV wheels and 395/85/20 XZL tires with "run flats" already installed. I have a couple quick questions before i begin mounting them. Does any one know the torque spec for the 20 bolts that hold the 2 halfs of the wheel together? Does anyone have any good advice for installing the tires onto the rims? I figured with them being a two peice design and the run flats already installed it would be smooth sailing but ive never done it before.
I know this is a terrible Photo but it is all i have. You can see the insert installed inside the tire on the left. The middle peice is quite large with bolts holding multiple peices together, The material seems to be plastic and not rubber like some of the photos of other "run flats" again ive never seen anything like this before and looking for a bit of guidance
