Fmtv wheel studs
Norinco666
77
Alabama
Can any of you fellas point me in the direction of the correct size rim studs for these lmtv wheels? Iam in need of a couple of the longer studs
frank8003
4,984
Ft. Lauderdale, Florida
This is not home depot stuff and I find none on the eBay.
5306-01-369-8893 Features
MRC Parameter Characteristics
AAJD Thread Class 3A
AAJF Thread Direction Right-hand
AASB Fastener Length 2.440 inches nominal
AASK Head Style Dee chamfer
AASL Head Diameter 1.060 inches nominal
AASU Head Height 0.220 inches nominal
AASY Distance from Centerline to Flat 0.3437 inches minimum and 0.3462 inches maximum
AATF Distance from Center of Head to Center of Shank 0.780 inches nominal
ABQZ Internal Drive Style W/O internal drive
AHYM Nominal Thread Diameter 0.625 inches
CMLP Thread Quantity per Inch 18
MATT Material Steel overall
MDCL Material Document and Classification Sae J429, GR8 assn std single material response overall
SFTT Surface Treatment Phosphate zinc overall
THSD Thread Series Designator UNF
simp5782
Feo, Fuerte y Formal
9,367
Mason, TN
Hemtt wheel halves bolts are 3/4" the LMTV wheels use 5/8" studs. Good luck finding longer ones.
Easiest to buy another wheel and salvage those
Swamp Donkey
The Engineer
119
Gray, GA
Parttarget lists Hutchison and Titan as distributors. You could call them and inquire about where to source some of those studs. From experience, Hutchison was very helpful when I was questioning them about runflats and I didn't buy anything from them.
Oshkosh Equipment has a PDF, that Google found, that lists that part number. That usually means they stocked it at one time. They might could help with sourcing as well.
I have also dealt with WBParts several times. They are one of the sourcing companies that come up when searching for military parts. Most will say that companies like that are extremely expensive. I've made 5 purchases from them and 4 of those came in well under what the part went for on Ebay or from the usual vendors. The 5th purchase was a part only they could get. If they're the only ones that can get a part then they can set the price in my opinion. You gotta pay to play. Just another option...
Honestly though, I wouldn't go to all that trouble for a couple of wheel studs if the above options don't work out. The only difference between that stud and a normal nut and bolt is the splines on the shank. The studs are designed so that all the work can be done from one side of the wheel. It's a necessity for lug studs to be this way so the whole wheel hub doesn't have to be disassembled to remove a wheel. On wheel studs though, you always have access to both sides since you have the wheel off when changing a tire. The critical job of the wheel stud is clamping the halves together. This can be accomplished with a nut and bolt since both sides are accessible.
I don't see a grade listed for the stud in any of the specs, so I'd use a G80 5/8-18 flange head bolt of the length you need and a matching flange head interference lock nut. Probably won't find those at your local hardware store, but a specialty fastener place like Fastenall should have them.
Where are all the nuts for those wheels?
Norinco666
77
Alabama
In my pants
Swamp Donkey
The Engineer
119
Gray, GA
In my pants
Seems questionable at best. With a childish comment like that, it's amazing that they've even dropped...
I was going to offer you a couple studs out of a bent wheel I had....AND enough new nuts to do all those wheels, since I have about 1200 new ones. AND they would've been all for the cost of shipping. But hey, you can spend your money now fool. Maybe Memphis can find you a towbar so you can drag that foot out of your mouth. D@mn youngin's and their mouths...
Norinco666
77
Alabama
Dont need any nuts or else i would of asked some you people get to offended ��
frank8003
4,984
wow
ramdough
1,729
Austin, Texas
Tried to send you a PM but your box is full.
Sent from my iPad using Tapatalk
