Fmtv wheel studs
jack/ny
11
Warwick NY
Do you have the part number from NAPA? I went there and they couldn’t find a match.
Have them pull the book out with wheel studs. It took my guy some time to find the right one, I think I left the one I brought in. The one he found was maybe 1/8” shorter than the original. They did have to order it, only took a day or two.
Jack
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Jack
Those are wheel studs that are at napa. Not beadlock studs on the wheel. Only certain distributors sell those
Maybe a moderator can adjust the title to be more specific. FMTV wheel beadlock studs would probably be accurate as that is what the OP was looking for. Not studs for the truck
jack/ny
11
Warwick NY
I got the beadlock studs at NAPA.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
These might work if you grind the needed flat spots? Wheel Studs
That link shows 7/16" studs. But we need 5/8"...
NAPA # 641-3141 (Post 28 ) is equivalent to GM #15725051. Some dimensions and vehicle application can be seen here...
Those are not the same as the stock FMTV wheel studs, but may eventually fit - after some grinding. (I'm not sure; never done it, myself...)
charlesmann
713
Temple, Tx
Seems questionable at best. With a childish comment like that, it's amazing that they've even dropped...
I was going to offer you a couple studs out of a bent wheel I had....AND enough new nuts to do all those wheels, since I have about 1200 new ones. AND they would've been all for the cost of shipping. But hey, you can spend your money now fool. Maybe Memphis can find you a towbar so you can drag that foot out of your mouth. D@mn youngin's and their mouths...
I know this is kind of an old thread. But do you by chance have a couple studs and nuts left? i looked at what my local napa offered, and the stud and nut didn't seem to match with what i had in my hand.
