obee1kubota
- 0
- 0
- Deerwood, MN
purrrfect
nicest tire look I have seen on a 818
Any idea where you can pick the regular valves up? 4 of mine are missing.Small sidebar info- I would pull the CTIS valves and hoses off those wheels and use the regular metal Schraeder valves, unless you really have the CTIS installed on your axles (obviously it is not in those pics where I can see the hub spigots).
Best regards,
Bob
Do you have the part number by any chance?With those larger tires your speedometer will be way off. you can correct your speedometer by replacing the "speedometer wedge" with one for 1400x20 tires. the speedometer wedge is the 90 deg adapter at the end of the speedometer cable underneath the truck. I bought mine from memphis equipment.
