Fmtv wheels ?
chucky
18,961
TN .
While im on a roll with dumb questions can i put say a 11/24.5 commercial truck rims on my fmtv 10 bolt hub ive never herd if its possible or not if you were to get in a bad way with no spare maybe drop front driveshaft to gain 2 spares and just put the regular truck rims on the front to get home on ???
chucky
18,961
TN .
I thought 22.5 was the common commercial size wheel.
The 22.5s got popular years back when they were trying to get every possible inch of freight in the newer trailers so smaller tires smaller wheels lower profile everything for more cargo space like with the length of trailers when the first 53 ft trailers hit the road it was just to haul empty plastic coke bottles and wil NEVER be used anywhere else lol and now thats all you see in freight trailers and they wernt going to be allowed on all the skinny roads yea rite !!!
simp5782
Feo, Fuerte y Formal
9,368
Mason, TN
22.5s and 24.5s will fit on the LMTV/FMTVs in dual form on the rear and even dual on the front if you really wanted to do it or needed it
12R24.5s are equal to 395s in height. Not common but available. If you didn't want to run a skinny steer then a 445 65 22.5 on the steer makes it nice and wide at the same 46in height
chucky
18,961
TN .
Im just showin my age all the big trucks still had 24.5 when i got out of them for buses ! Im glad to know they fit so you can come home on 22s or 24s and now youve got me thinking what it would look like with the back of a 1083 dual out ??? I was hopeing to find a work around for just in case ! GOOD DEAL THANKS
chucky
18,961
TN .
Oh and with these small studs are the trucks all small stud now (hub piloted) with the washers made to them or just some of them ?
simp5782
9,368
Mason, TN
No they are the sma budd. 3/4"-16 stud. like the 5 tons use. You can put a budd thimble on them for duals. The larger stud for the ctis banjo uses a 7/8 thread pitch like the 915s and 920s run on their steer as well as older road trucks used.
The hub pilot pattern is close but not exactly . Threads are totally different than the m22 that hub pilots use. [The washer ones]
chucky
18,961
TN .
Ok good to know and back to the 11/24.5 so i could actually put one in any of the postions on the truck without pulling axles or shafts the tire height is close enough to bolt it on and run it ????
chucky
18,961
TN .
When i got away from truck world the hubs had small studs you put the inside on then screwed another stud to hold onto the small stud then put the outside on and put the big hole 1 1/2 inch nut on the inner stud to hold them all together ! I have no idea what they use now im not around it anymore .
