MarkM
CODE BROWN...It's all going to sh~t !
- 1,150
- 2,099
- 113
- WOBURN. MA.
As long as you connect up to two 12v batteries correctly yes. Just like when you test the individual batteries with a multimeter.
Mark
Mark
YES! Why wouldn’t it be?So its safe to charge the batteries with a 12v dual bank charger while they're connected together as 24v ?
.Where do you get those
In the case of the NOGO Gen series, yes. For other brands (and some other NOCO models) the answer will vary. Sometimes they require the negative side of each bank to be common, which means it will only work for 12v batteries in parallel.So its safe to charge the batteries with a 12v dual bank charger while they're connected together as 24v ?
See my post above, for some chargers this is not supported. Its important to verify.YES! Why wouldn’t it be?
A others have stated, you do need to verify with the manufacturer before trying this with a charger.So its safe to charge the batteries with a 12v dual bank charger while they're connected together as 24v ?
I sent you a PMWhere do you get those
I love these chargers. Marketed under different names but as far as I can tell are all the same.
I alter them to terminate into an Anderson connector instead of being hardwired, and then add a slave plug and cable terminated in an Anderson connector and add an Anderson connector to the alligator clips. This gives the ability to either charge batteries individually , or charge them all together through the slave port.I love these chargers. Marketed under different names but as far as I can tell are all the same.
Anhyczyx 12V/24V Smart Pulse Repair Battery Charger Intelligent Mode LCD Display | eBay
Find many great new & used options and get the best deals for Anhyczyx 12V/24V Smart Pulse Repair Battery Charger Intelligent Mode LCD Display at the best online prices at eBay! Free shipping for many products!www.ebay.com
