Ford solenoid used to replace stater relay
Jakob
Louisville, KY
So I posted a thread a while back about my truck not starting. I finally got some time to get around to it. I couldn't readily find a stock replacement relay, so I grabbed a Ford fender mounted solenoid and swapped it in. Once I did that, the truck fired to life! What are the ramifications of using a 12v solenoid on a 24v system?
papercu
31
Baxley, Ga.
Nothing, I put one on a truck 4 or 5 years ago and it's still there. If you have to do a lot of cranking it may go out faster. Wayne
halftrack
9
New Orleans, LA
You know you don't even need the relay. Just about all the trucks I have come across when they were overhauled they removed the relay and just connected directly to the starterd. It makes one less part to brake later on. I usually take them off the trucks I get and throw them away.
Jakob
Louisville, KY
I haven't looked closely at the system, I just threw the Ford solenoid in there. Do the two wires from the stock relay get wired together, then the signal wire go to the starter solenoid?
