Found a couple Jerry Cans at a local flea market today......
stugpanzer
10
Sandwich, IL
The guy wanted $12 each for them so I offered $20 for both and he accepted. I am going to clean them up a bit and fill with water to see if there are leaks. I suspect the one dated 1952 has a leak since its a bit oily on the bottom. If no leaks then I will finish cleaning, paint and then use them on my MEP-803a trailer.
csheath
197
FL
I think I have one in my shed but it's burried. I saw the spout on a shelf the other day.
Bmxenbrett
30
They make gas tank leak coat/stopper stuff that works prety good. So even if they leak its not a total loss.
dmetalmiki
2,027
London England
I have some 'spouts' I purchased at an event, The seller said "they fit any can, U.S. or British".
I was was sceptical..But guess what?. They sure as heck do.
jagrdawger
SD
Spouts...huh...spouts? must be a civilian term for something on a fuel can. Never heard them called anything but the 5th appendage of a hybrid equine in 22 years of active duty...LOL :deadhorse:
Bmxenbrett
30
Not sure on brand. A friend used it on a 3 wheeler fuel tank that had many pin holes. Little bondo and paint and the thing looked show room clean. But these tanks without holes/rust are close to $300
Chainbreaker
1,855
Oregon
If you do decide to use Red-Kote just make sure those Jerry Cans never held diesel. Here is Red-Kote warning:
"Diesel Fuel Tanks - A brand new tank intended for
use with diesel may be lined prior to use. A tank that
has had diesel fuel in it will need to be sand blasted
prior to using Red-Kote. Diesel fuel leaves a paraffin
coating inside the tank that Red-Kote will not stick to.
There is no known cleaning method to remove this
paraffin coating other than sand blasting. If you choose
to line a diesel tank you do so at your own risk."
View attachment Red-Kote.pdf
USAMilRet
15
Tampa, Florida
IIRC, when I was in the military they were called "Donkey Dicks". Never heard them called anything else than that, even when doing a change of command inventory. They were made of flexible metal tubes and you could never find one when you needed it.
We did find a stash in the WAC Shack at one time.... :)
