- 9,576
- 211
- 63
- Dickson,TN
If the bottom end looks good and there are no unusual noises, I believe I'd button it up and run it.
Thanks - I'll just manuever them back into their slots.You should be able to just push the tappets in and be good to go. They are a loose enough fit so they can slide up and down easily. You can probably do it with one of the push rods.
The engine is not a rebuild - at least thats my assumption since there is no rebuild tag, and only the original installation plate on the block. These id plates have been wrong before though - so anything is possible.It's weird about the push rods. Is it a rebuild engine? Maybe they got damaged before they were put in the engine and the rebuilders thought it wouldn't hurt anything and used them anyways. I don't see how anything in the engine could have caused that damage.
X2! its a omen of bad things to comeI would say any metal in the pan would be a very bad thing.
