Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I've got a set of the old welded style that I'd sell for alot less than $177. One is bent a little but if you've got a torch and a big hammer it shouldn't be that big of deal. I was going to fix it and use it myself but I've come across another set so I don't need these. Give me a PM if your interested.
You will need frame extentions and winch mounts. Saturn Surplus has 1 side NOS winch mount for $30. I forget which side. They only have the one side tho. I have a set of frame extentions and a good right side winch mount. The left side requires some fabrication. Someone cut the top part of the winch mount off. There is a fellow close to you that has alot of deuce parts. Forget exactly where but he is around the Lincoln/Omaha area. And finally you will need about a 10" bolt for the mounting. Make sure you get this with the set up. It is a very expensive grade 8 bolt/nut.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
