Frame number M1009
CUCVM1009
Muenster / Germany
Hi.
I´m searching for the GM-frame number of my 83/84 M1009.
I need this for the restauration process!
The following chart is a screenshot from my ´83 shop manual
Thanks!!! :grin:
Greetz from Germany!
Sebastian!
CUCVM1009
Muenster / Germany
Hi and thank you for your search!
I mean the "model number" on the left side of the chart!
Is it the K105?
I need this for building a holder for the bodyshell in my rotisserie.
Hasdrubal
Vancouver BC
Looking at those numbers and comparing it to a Mitchell/KLM Automotive Frame Measuring Book. It doesn't seem to quite match any. Looking at column P on your chart, the KLM numbers are 48 1/8". Column R, the KLM numbers are 84 3/8". Here's a smaller picture, you can compare the measurements yourself.
cucvrus
10,427
Jonestown Pennsylvania
Hi.
Thanks!!! :grin:
Sebastian!
The measurements you have look about the same as everything i looked at. Is there something special you need measured? I have 2 M1009 frames sitting around. If you need anything let me know. I can measure for you. Also have several of the brackets and cross members for the frames. Good Luck.
CUCVM1009
Muenster / Germany
Hi!
This forum is awesome! :hammer:
Cool research!
I need the difference of the hight from the cabmountbrackets.
The plan is, to use a mainbar of squaretube and slip four cabmountbars on it. (variable). So I can take off the body, pull out the chassis and put the body directly on the rotisserie.
I have not so many place to work in my garage. (6m x 9m) All is strictly organiced to make that project! :mrgreen:
@cucvrus:
I´ll confirm your offer! :D
@ all others:
:goodjob:
There are a lot of useful links! Great! Thanks!
I´ve took al lot of pictures by now! A photostory follows, when the baby is nearly ready. It takes a lot of time!
In a couple of weeks, our first child will be born! :jumpin: I think, the M1009 sits a litle bit longer on his place...
But sometimes, I will escape into my "men cave", I believe!
