freewheel axle flanges
steve6x6x6
37
Winter Haven, florida
I have a set of Deuce hubs machined ten thousandths over spline OD. No bushings. I've run them a few hundred miles with no problems.
I like the addition of the grease fittings! I'll copy that.
You are right, there is no need for any hard steel or bronze bushing in the desplined cap. I have machined the splines from the M35 drive caps and i can tell you they are still harden steel there with the splines gone.
welldigger
Benton LA
I agree with you steve. I don't see why so many people made a big deal out of putting a bronze bushing in the desplined caps. The axle sits inside the spindle and neither the spindle nor the axle shaft will be rotating. The cap will simply rotate around the axle splines. Nothing will be moving or flopping around to worry about.
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
I think the reasoning is that you will have steel on steel. If you had a bronze bushing in there, it would wear (which it will) instead of your axle shaft after a lot of miles.
welldigger
Benton LA
How would there be any steel on steel if you machine enough clearance for the axle splines?
73m819
327
gainesville, ga.
On the deuce, there is NO NEED for a bushing because of the TWO bushings in the spindle, ONLY the 5ts need a bushing because there is only ONE bushing in the spindle and it is at the rear of the spindle, the cap supports the front of the axle.
steve6x6x6
37
I have not seen two bushings in th M35, there is one bushing in the spindle.
