Freeze plug Woes
motormayhem
Tucson, AZ
Well my truck has been parked for the last month and I noticed a few drops of fluid on the axle and ground. After looking into it it looks like the drivers side freeze plug under the engine mount in leaking. Is this indicating a head gasket problem? What needs to be done to fix it? It runs about 195-205 when it is 105 outside and has had a radiator leak and failed heater hose in the last 6 months. Doesn't go through fluid and oil and coolant seem to be separated as far as I can tell.
eric_banks32
Granite City, Il
Freeze plugs corrode from sitting for long periods and improper coolant/water mixtures. If your positive its coming from a freeze plug, you can drain the coolant and put a new freeze plug in and down the road ya go.
motormayhem
Tucson, AZ
Well if it is any indication when I got the truck 2 years ago the coolant was dirt brown and it took 4 flushes and radiator clean out stuff to get the fluid to cleanup and the radiator was 50% blocked. I think that means someone wasn't keeping my freeze plugs rust free.
Well it looks like it is gonna need to be replaced. In the wiki it says a block heater should be a 41mm does that mean the freeze plugs are also 41mm.
Any words of wisdom to change the one above the motor mount without pulling the entire motor?
