Freezing Parking Brake
Ronmar
8,398
Port angeles wa
If you are just using shop air to charge the tanks before start, you are probably not introducing much moisture. The giveaway would be if you get any moisture out of the tank drains. If you are not getting any moisture out the tank drains then you are probably not admitting enough moisture to really condense anywhere else, especially when you consider how much air runs thru a brake system, let alone a system that also feeds massive tires…
