- 32
- 62
- 18
- NW Indiana (USA)
Hi all,
in the process of hooking up a Tach i got from amazon.
I'm trying to figure out what the relation is between the Frequency @ AC terminal on the N3135 Regulator and the actual engine RPM's.
Measuring with a scope was about 120Hz at idle (guess around 700-750 RPM) see attached picture.
This weekend i will try to measure the actual rpm with a handheld tach on a motor pulley if i can find a safe spot to do so.
or measure crank and alternator pulley and some math to calculate freq and rpm ratio
(M1123 6.5L NA) 4Speed
