Fresh Line-X in the M1009
readyman
Elk Grove Village, Illinois
For the purists who want that 383CARC 'look' in their M1009 interior. The Line-X guy did a great job of color matching with their upgraded KEVLAR formula. I did all the prep work myself and drove 20 miles to the Line-X dealer with only a seat and a speedo. :cool: Because dealer disassembly was $.
Looking forward to revising the inside door stencil - Hose down interior only. :smile:
I welded up/Line-X'd a mount for the 40mm ammo can center console, that's the thing sitting on the hump.
I found out both Upol and Sem Bedliner has a tintable 'Do It Yourself' package for a fraction of the cost, only after I had Line-X do it. :x
Next thing to do is set off a 383CARC bomb in the interior without messin' up the Line-X job.
ARYankee
31
Benton, AR
I like it!!! It looks great! I did the DIY bedliner. It came out OK, of course, not as good as a professional job but works for me. I like that yours is color matched [thumbzup]
lavarok
33
Fellsmere, FL
Looks like they did a nice job and it looks great.
Line-X has a lifetime warranty and is much tougher than any DIY kit.
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
I think it looks great! I am interested in finding out how much it cost, and whether the liner quiets down the interior at all. Thanks for sharing the pictures!
readyman
Yeah, driving it home with the huge empty interior was a noticeable quieter ride than the ride there.
I also did the polypropylene plastic air vent panels, so they can do more than metal coating.
readyman
That's right DieselBob, in order to get the color match I had to upgrade to the Line-X XTRA coating with Kevlar!?!
I made sure they went far up the firewall in case my 6.2 crank cracks in half(at speed) again, like in my HMMWV. :roll:
I picked up a load of Line-X'd parts for another project but the CUCV parts still weren't done yet so I still don't have a price yet.
That looks very good. Don't forget that bed liner will also help keep explosions under the vehicle from penetrating the floor. :)
CycleJay
Marietta, Ga
re; Fresh Line-X in the M1009
Hello Readyman,
The line X job looks great, I would liked to get my interior professionally lined too, when I can afford it, so it can get done right, and it will be tougher,
than doing it myself. But I will consider doing it myself anyway, we shall see..
But what do you mean by a 383 CARC bomb?
Keith_J
1,316
Schertz TX
Looks great but quite expensive. I'm looking at Lizardskin thermal on the outside and sound on the inside bottom with thermal on the headliner. Then custom fit rubber mat on the floor. This will help on the heat and noise.
readyman
I was joking around, the busting crank wasn't all that exciting. We were going 60mph with all systems and gauges normal. Then POW. 0 oil pressure and the 6.2 continued to run as I drove to the shoulder. Scratched my head for a while until I saw the crank pulley idling with an inch of end play. :???: It started and idled rough even after that. It had 4500 miles and was an arsenal rebuild.
Dare I ask what happened "At Speed" when your crank shaft parted ways?
