Friend's truck: conversion from turbo 400/NP208 too a 700r4/NP205
peglegwillie
Knoxville Tennseess
I will use two sticks. Had them in a dewranglered 87 Jeep T18 300tc 9" ford Detroit locked rear dana44 up front. Worked great towed a trailer with ton load up trail in mountains NC twisted rear shaft shifted rear neutral. Front only low range drove it back out !
coecamo
Canton Mich
700R4 requires a diesel governor and if this a gas trans you need the BEAST SUNSHELL and better if you install a shift mod piston if 1-2 shift is harsh. I did the 700R4 swap with the 208 T-case wish you well
