- 26,246
- 1,193
- 113
- NY
i am about 45 minutes east of pittsburghWhere abouts in PA are you? I have a brand new pair of solid Silicone boots with clamps that I am not using right away. Jim
Nice idea on the seal. I'll try that next time I pull the hubs to do the bearing.Also I use a rear outer wheel bearing seal on the front axle. Basically put it together just like a rear hub bearing set. 2-3 times now a little water has got around the boot and into the wheel bearings. I had a seal on one side, and not the other. The one with the seal had nice grease still in it, the other one had ruined bearings.
Now back to putting the truck together!
