- 56
- 0
- 8
- Freedom, NH
Guys- I need some help again. My M35A2C has developed a drip from the front axle air switch on to the tranny hump that has me baffled. At first I thought that it must be oil from the oil pressure gage above the switch but it appears to be coming from the transfer switch itself. Since my air is drained regularly and there is no crud build up, it must be coming from the line up from the transfer case. Unless I am mistaken, this switch vents the pressure off when the front axle is reverted back to 4X6 leaving that line as an open vent. I checked the level in the transfer case and it is normal. I could just run a vent line outside the firewall but all that would do would be to mask the problem. Any suggestions? Thanks in advance-----> Les
