- 667
- 146
- 43
- International Falls, MN
Lol, now that's funny no matter who you are!!
He didnt say it was "Locked" in. He said it is 6x6 in all gears, not just first or reverse.Partner, you are the one who said it was "locked in" in ALL gears. Read the first sentence of post 14. Just because you can read the TM doesn't mean you understand it.
If it were in 6x6 in all gears that would infer that the transfercase is engaged or "locked in" and all 6 (or 10) tires are receiving power all the time. It is in 4x6 until the slip engages the sprag no matter what gear the truck is in. That's what I was getting at.He didnt say it was "Locked" in. He said it is 6x6 in all gears, not just first or reverse.
The t-case is never locked in 6x6 in any gear.
The airshift and REB modified transfer case are "locked in". The sprag is not.If it were in 6x6 in all gears that would infer that the transfercase is engaged or "locked in" and all 6 (or 10) tires are receiving power all the time. It is in 4x6 until the slip engages the sprag no matter what gear the truck is in. That's what I was getting at.
That they are! Anyways, lets not take the original thread anymore in the wrong direction than we already have!The airshift and REB modified transfer case are "locked in". The sprag is not.
GotchaIf it were in 6x6 in all gears that would infer that the transfercase is engaged or "locked in" and all 6 (or 10) tires are receiving power all the time. It is in 4x6 until the slip engages the sprag no matter what gear the truck is in. That's what I was getting at.
Not so, it is only in 6x6 in 1st and reverse and its locked in. The other gears, the rear tires have to slip 20% for the sprag to engage.
I've taken apart three sprag transfer cases. In each one, the forward sprag was worn out but the reverse was fine. You COULD use two reverse sprag sections to make one good set. But, then you have to find and pay for another sprag transfer case. I agree that it is better to move to an air shift and that is what I did.On every sprag deuce I've been in, the sprag didn't work right. I honestly don't know how good a working sprag is because I've never been in a deuce that worked (I have had 5-tons that the sprag worked). .
Sorry, I have a hard copy.I would like to read section 86 in TM9-1819B which describes how the single sprag and dual sprag work.
I really would.
I have no answers to my search for TM9-1819B section 86.
Did I just completly miss it as it it right here on SS?
I have been lost in
http://archive.org/stream/PAM310-4/PAM%20310-4_djvu.txt
I did find this interesting thru google and back to SS
http://www.steelsoldiers.com/showthread.php?3299-Air-shift-or-REB-kit&
Please someone send a link or an address or a place to go to read section 86 in TM9-1819Bt.
