Front axle seal???? help
hfccar6
port jervis/NY
Ok well i have been doing work on my fire companys 52 m37. I had changed the fluid in the front diff and after that i had gear oil come out of the drivers side hub. I have taken abart the entire front hub apart expecting to find a seal some where but i didnt. Can anyone help me out and tell me if and where it is located. I have the original service manual and it just says if gear oil found in the front hub contact battalion maintnance. Any help is greatly appreciated.
Oh and on a side note, i just installed the snake river 4x4 power steering conversion. I absolutley love it very easy to install ,simple easy to follow instructions. Well worth the price, best money my fire co. has spent on the truck.
M543A2
11
Warsaw, Indiana
I have attached a copy of the axle housing breakdown. It shows the seals in the end of the housing, "J" in the illustration.
This book is from Memphis Equipment Company,
Regards Marti
Mike_L
9
Marion, IN
The bearing/bushing in front of it ("H" in the illustration) is a bear to get out. Most of your standard pullers won't reach back far enough to get a good bite on it. Be careful pulling the bearings, they are reusable if they don't get dinged up.
Most, including myself, have rigged up a slide hammer with some bar stock behind it with some success.
Roller
56
North Lake, WI
Chances are that if the seal is leaking the bronze bushing is worn oversize or the axle bearing surface is worn below service limits allowing the axle excess movement within the housing and defeating the seals purpose. Measure the axle and bushing in addition to replacing the seal. As stated above, a slide hammer is a good way to remove the bearing and also the seal.
Frank
