- 7,409
- 2,503
- 113
- Interlachen Fl.
OK I did look through some TM's I swear. I have two vent lines connected to the passenger side mid axle housing. I removed both and put some air to both. One I can hear the one and it seems to be right above the front axle just hard to see where it ends but is up in the frame. The other there is a release of air but I can not figure out where it ends up. I am turning the 1088 into a off road mud truck to just use at the local mud pit. I am / want to relocate all three axle vents to a much higher point. I just want to be sure to cap off the one I can not find the end too if it goes somewhere that might take on water. Tanks
