Front brake drums on M38A1
jeeplvr247
10
Ferndale, MI
I have heard not to use moly grease in the GAA applications because GAA is lithium based. I just planned on using my Lucas Red and Tacky. It is good grease and has served me well in the past. The new wheel bearing is packed in light cosmolene so I will clean it with gas as you suggested. When I put the axle back in, should the whole shaft be greased or just the splines?
Edit: Although now that I look deeper into that grease question I don't see anything against the moly grease on the compatibility charts...
