Front disc dust shield
Have checked the TM's and they only show a single piece part. When several bolts holding the dually spacer to the disc and hub backed out, they trashed an inner dust shield. I can see no failed spot welds, is there another piece that is not pictured in the TM or is it a single piece made of two attached parts?
In any case I need a right side one for an 8 bolt hub. Anyone have one kicking around?
cucvrus
9,613
Jonestown Pennsylvania
Run without it if you can't easily find one. Who would ever know? It is a dust cover. Like I said. Unless you are mud bogging and desert running I doubt it does much. Grease slinger guard. I like new vehicles. Sealed hubs and bearings. Over 200 K on a few trucks and the bearings are still stock original. Or tap out the dents that you can and just use it again. Making one would be possible but not economically effective.
