Rustyshackelford
- 10
- 18
- Tucson AZ
I asked the guys over at ORD about lifting the Blazers 4" and they sent this back about the front driveshaft.
"The front driveshaft has “stops” that limit the angle it can take, because at stock height they want the driveshaft to not be able to reach the ground in case a u-joint breaks. You can grind those out and then the front should work."
Has anyone had experience with this? Is it easy to grind?
